Editing a Versioned SDE FC using python - Error
2468
04-23-2019 05:59 AM
BrittanBattles3
Getting the following error below when trying to edit a versioned feature class in an SDE database using a python script tool:
File "L:\Tools\Models\ReconcilePostCalcFields&RecreateVersions.py", line 32, in <module>
for row in cursor:
RuntimeError: workspace already in transaction mode
Code is below:
import arcpy, os
# Set workspace
workspace = "Database Connections\\Connection to gis-prod.sde"
# Set the workspace environment
arcpy.env.workspace = workspace
# Create Version using SDE credentials
arcpy.CreateVersion_management (workspace, "sde.default", "fieldcalcs", "PUBLIC")
# Delcare variables
##versionList = arcpy.ListVersions('Database Connections\\Connection to gis-prod.sde')
inFeatures = "sde_m.SDE.PARCEL"
zip5expression = "!MAIL_ZIP![0:5]"
fl = "fl"
# Change Workspace to access data via OS Auth.
workspace2 = "Database Connections\\SDE_MPL_PROD_OSAUTH.sde"
arcpy.env.workspace = workspace2
# Create Feature Layer for editing
arcpy.MakeFeatureLayer_management (inFeatures, fl)
# Change Version
arcpy.ChangeVersion_management (fl,"TRANSACTIONAL", "sde.fieldcalcs")
# Start an edit session. Must provide the workspace.
edit = arcpy.da.Editor(workspace2)
# Edit session is started without an undo/redo stack for versioned data
edit.startEditing(False, True)
# Start an edit operation
edit.startOperation()
# Calculate the MAIL_ZIP5 field
fields = ['MAIL_ZIP5']
with arcpy.da.UpdateCursor(fl, fields) as cursor:
	for row in cursor:
		row[0] = zip5expression
		cursor.updateRow(row)
# Stop the edit operation.
edit.stopOperation()
# Stop the edit session and save the changes
edit.stopEditing(True)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
If I comment out the UpdateCursor section, the script runs successfully. I have also tried to reconcile, post and delete the child versions before executing the script with the same failure, all locks on the database are shared locks. I thought by versioning and editing, I could get around any locking issues. Any idea how to get the workspace out of transaction mode to allow editing to the child version created in the script?
BirajaNayak
This is a known issue and defect number is #BUG-000114598. It states that "RuntimeError "workspace already in transaction mode" occurs when using da.UpdateCursor on TableView after changing the version."
Workaround steps are provided below:
1. Change the connection file to point to the desired version.
2. Use the CreateDatabaseConnection_management tool to generate a temporary connection file pointing to the desired version. Delete when the script finishes.
3. Use a config file to store the arguments for the CreateDatabaseConnection tool to keep the username and password out of the script.(optional)
This is a code snippet used in another user case with similar situation:
At the beginning of your script:
temp = r"C:\Temp"
file = "SDEConn"
arcpy.CreateArcSDEConnectionFile_management(temp, file, <Fill In The Rest With Your RBDMS Parameters>)
workspace = os.path.join(temp, file +".sde")
At the end of your script:
arcpy.Delete(workspace)
Hope that helps.
Biraja
