Differences between our Dashboard Portal and an Esri Dashboard account
2871
04-22-2019 11:54 PM
BrainsREBrainsRE
I am trying to configure a dashobard in our own Portal with ArcGIS Enterprise 10.6.1 but I have found differences between our Portal and an Esri account.
I need to configure a serial chart with the sum of values added in categories and limit the result to 5 columns, but this option does not appear in our Portal if I select "Grouped Values". It only appears if I select "Features".
DerekLaw
Esri Esteemed Contributor
Hi Aura,
The release of Operations Dashboard in ArcGIS Enterprise 10.6.1 is slightly "behind" the Operations Dashboard release in ArcGIS Online. Hence why you may see more functionality in ArcGIS Online than in ArcGIS Enterprise.
Hope this helps,
SNyquist
I noticed this issue with my version of Portal (10.8). The Filter Tool is missing. Is this tool in the latest release of portal?
