How to add an attribute pop up to web app with multiple layers javascript
583
04-20-2019 07:53 PM
JohnnyHarley
Hi I am trying to add a attribute pop up when clicking on a census tract for my "cities" feature layer. I obviously haven't added any attributes to the infotemplate yet but whenever I run this code, there is no map that shows up, I take it out, and my map runs just fine. I just want the infotemplate for the cities feature layer. Thank you!
<!DOCTYPE html>
<html>
<head>
  <!--The viewport meta tag is used to improve the presentation and behavior of the samples
    on iOS devices-->
  <title>Checkbox</title>
  <link rel="stylesheet" href="https://js.arcgis.com/3.28/dijit/themes/nihilo/nihilo.css">
  <link rel="stylesheet" href="https://js.arcgis.com/3.28/esri/css/esri.css">
  <link rel="stylesheet" href="css/layout.css">
  <style>
    html, body {
      height: 97%;
      width: 98%;
      margin: 1%;
    #leftPane {
      width: 30%;
    #pane1 {
      border: solid #97DCF2 1px;
    #header{
      border: solid #C0C0C0 2px;
      background-color:#C0C0C0
    #HomeButton {
      position: absolute;
      top: 98px;
      left: 26px;
      z-index: 50;
    #legendPane {
  </style>
  <script src="http://js.arcgis.com/3.28/"></script>
  <script>
    var map;
    require([
            "dojo/parser", "esri/map", "esri/dijit/HomeButton", "esri/layers/FeatureLayer", "dojo/on", "dojo/dom", "dojo/dom-construct", "esri/dijit/Legend", "dojo/_base/array", "dijit/form/CheckBox",  "esri/dijit/BasemapGallery", "esri/dijit/Geocoder",
            "esri/graphic", "esri/symbols/SimpleMarkerSymbol", "esri/geometry/screenUtils", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/layout/AccordionContainer", "dojo/domReady!"
    ], function(
      parser, InfoTemplate, Map, HomeButton, FeatureLayer, on, dom, domConstruct, Legend, array, CheckBox, BasemapGallery, Geocoder, Graphic, SimpleMarkerSymbol, screenUtils, Color,  domConstract, BorderContainer, ContentPane, AccordionContainer
      parser.parse();
      //Create the map
      var map = new Map("map", {
        center: [-80.734, 28.297],
        zoom: 10,
        basemap: "topo"
      //Add a home button
      var home = new HomeButton({
        map:map
      }, "HomeButton");
      home.startup();
      //Add Feature Layers
 map.on("load", initOperationalLayer);
 function initOperationalLayer() {
   var infoTemplate = new InfoTemplate();
      var cities = new FeatureLayer(
          "http://gis.nwmissouri.edu/msgis642/rest/services/Harley/MEANAGE/MapServer/0", {
          mode: FeatureLayer.MODE_ONDEMAND,
          outFields: ["*"],
    infoTemplate: infoTemplate
      var rivers = new FeatureLayer(
          "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/1", {
          outFields: ["*"]
      var states = new FeatureLayer(
          "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/2", {
          opacity: 0.5,
          outFields: ["*"]
            //add the legend
      map.on("layers-add-result", function (evt) {
          var layerInfo = array.map(evt.layers, function (layer,
          index) {
              return {
                  layer: layer.layer,
                  title: layer.layer.name
          if (layerInfo.length > 0) {
              var legendDijit = new Legend({
                  map: map,
                  layerInfos: layerInfo
              }, "legendDiv");
              legendDijit.startup();
                //add check boxes
          array.forEach(layerInfo,
          function (layer) {
              var layerName = layer.title;
              if(layerName != 'AGEMEANTRACT'){
              var checkBox = new CheckBox({
                  name: "checkBox" + layer.layer.id,
                  value: layer.layer.id,
                  checked: layer.layer.visible,
                  onChange: function (evt) {
                      var clayer = map.getLayer(this.value);
                      clayer.setVisibility(!clayer.visible);
                      this.checked = clayer.visible;
                    //add the check box and label to the TOC
              domConstruct.place(checkBox.domNode, "layers",
                  "after");
              var checkLabel = domConstruct.create('label', {
                  'for': checkBox.name,
                  innerHTML: layerName
              }, checkBox.domNode, "after");
              domConstruct.place("<br />", checkLabel,
                  "after");
      map.addLayers([states, rivers, cities]);
      //Create the Basemap
      var basemapGallery = new BasemapGallery({
        showArcGISBasemaps: true,
        map: map
      }, "basemapGallery");
      basemapGallery.startup();
      basemapGallery.on("error", function(msg) {
        console.log("basemap gallery error:  ", msg);
  </script>
</head>
<body class="nihilo">
<div id="content" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:true" style="width: 100%; height: 100%; margin: 0;">
  <div id="header" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'">
       <strong>Layer Checkbox</strong>
  </div>
  <div id="leftPane"       data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'">
    <div data-dojo-type="dijit/layout/AccordionContainer">
      <div data-dojo-type="dijit/layout/ContentPane" id="pane1" data-dojo-props="title:'Base Maps', selected:false">
        <div id="basemapGallery"></div>
      </div>
      <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="title:'Layers', selected:true">
          <span style="padding: 10px 0;">Click to toggle each layer on or off</span>
          <div id="layers"></div>
      </div>
      <div data-dojo-type="dijit/layout/ContentPane" id="legendPane" data-dojo-props="title:'Legend', selected:false">
        <div id="legendDiv"></div>
      </div>
    </div>
  </div>
  <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'" style="overflow:hidden;">
  <div id="HomeButton"></div>
  </div>
</div>
</body>
</html>
KenBuja
MVP Esteemed Contributor
The big problem was your function arguments did not match the order that the modules were called in the require.
This code works (and is centered on Kansas City)
<!DOCTYPE html>
<html>
<head>
    on iOS devices-->
  <style>
    html, body {
      height: 97%;
      width: 98%;
      margin: 1%;
    #leftPane {
      width: 30%;
    #pane1 {
    #header {
      background-color: #C0C0C0
    #HomeButton {
      position: absolute;
      top: 98px;
      left: 26px;
      z-index: 50;
    #legendPane {
  </style>
  <script src="https://js.arcgis.com/3.28/"></script>
  <script>
    var map;
    require([
      "esri/InfoTemplate",
      "dojo/domReady!"
    ], function (
      parser, Map, HomeButton, FeatureLayer, on, dom, domConstruct,
      Graphic, SimpleMarkerSymbol, screenUtils, BorderContainer, ContentPane, AccordionContainer,
      InfoTemplate
        parser.parse();
        //Create the map
          center: [-94.7, 39],
          zoom: 10,
          basemap: "topo"
        //Add a home button
          map: map
        }, "HomeButton");
        home.startup();
            "https://gis.nwmissouri.edu/msgis642/rest/services/Harley/MEANAGE/MapServer/0", {
              outFields: ["*"],
            "https://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/1", {
              outFields: ["*"]
            "https://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/2", {
              opacity: 0.5,
              outFields: ["*"]
          //add the legend
              index) {
              return {
                layer: layer.layer,
                map: map,
              }, "legendDiv");
            //add check boxes
              function (layer) {
                if (layerName != 'AGEMEANTRACT') {
                    "after");
                    "after");
            map: map
          basemapGallery.on("error", function (msg) {
  </script>
</head>
    </div>
        </div>
        </div>
        </div>
      </div>
    </div>
    </div>
  </div>
</body>
</html>
