update values in input connectors
2645
04-22-2019 06:52 AM
Pa_Lotus
Hi
I was looking for is there anyway to run a job and update a token(Header Parameter Name: Value lIst) in input connector type "poll an external website for json".
how to get control of input connector and update the fields in it.
Thanks In advance
RJSunderman
Hey MR -
I would recommend you take a look at the following blogs:
What you want to do requires you write a script or web application which uses the ArcGIS Server Administrative REST API. You can review available operations exposed by the Admin API:
  1. Browse to https://my-machine.domain:6143/geoevent/admin
  2. Acquire a token from your ArcGIS Server (or Portal for ArcGIS if federated) and log-in
  3. In the top-left corner, click the API link to take you to the Swagger Doc for the GeoEvent Server Admin API
  4. Note the advice at the top of the page on how to authenticate your admin script's requests with the API
Good Luck -
RJ
DanielCota1
Hi MR Reddy
Just to clarify, are you looking to be able to have the input connector's Header Parameter Name:Value List property be automatically/programmatically updated while the input is running?
Pa_Lotus
Hi Daniel Cota
Thanks for your reply
Yes, I was looking for Header Parameter Name:Value List property to be automatically/programmatically updating.
In my case, I will pass token in the Header Parameter Name:Value  property,
token will expire in a week, so I created a separate code to generate token and store it in local file.
so am planning to get the token value from the file and automatically update in input connector.
can this be achieved or I need to create a new transport?
RJSunderman
Hey MR -
Good Luck -
RJ
EricIronside
Hey Everyone,
I just updated my GitHub repository hosting the python scripts for my blog Scripting tasks using the GeoEvent Admin API - Update Inputs to include a python script that will update either URL Parameters OR Header name:value properties. Look for the python script UpdateGEEInputURLorHeadParam.py.
Best,
Eric I.
