How to select specified values for attribute tables?
1223
04-18-2019 06:09 AM
CarstAway
first, sry for my english!
I have to copy one attribute column of an attribute table (>200k values) in the same attribute table.  This attribute column has around 40 different values, but for the copy I just need around 5 defined values. All other values have to been deleted. What is the fastest way to do this for big data like this?
Second problem: I have to rename (shorten) this 5 values in the new column ot the attribte table, what is the best way to do this?
Best wishes,
Carstaway
ColeAndrews
Do you know what a definition query is? Add a definition query to the layer so that only the 5 values are present in the table. Then copy the fields.
CarstAway
thank you very much!
This is an good idea for the selection. But this leads to another problem:
I have to rename the values in the new column of the attribute table, like "tree" to "plant", is there any function for this? Or do I have to rename each value by hand?
