How do you remove a single redo operation from the undo/redo stack in the ArcGIS Pro SDK? (FindRedoOperations,RemoveRedoOperation)
415
04-12-2019 08:33 AM
JohnPhillipsGeo
Hello, I am new to the .NET SDK for ArcGIS Pro and haven't found any documentation on this particular subject.
I have a workflow that requires me to remove a single Redo operation from the undo/redo stack.  I have found the FindRedoOperations() and RemoveRedoOperation() in the SDK Documentation however I can't seem to figure out how to use them.  Can someone please provide an example of how to use these two functions?
//Create Edit operation
var splitFeatures = new EditOperation() { };
//perform a split and execute
splitFeatures.Split(lyr, oid, geometry);
splitFeatures.Execute();
//Here I do some analysis on the split segment then I undo the split
<--Some extraneous code here-->
//Undo the split
splitFeatures.UndoAsync();
//I would like to remove the option for the user to redo the undo on the split that I've implemented here.
//operationMgr.FindRedoOperations()
//RemoveRedoOperation();
