How to deploy a configuration to a machine instead of a user
756
04-12-2019 12:09 AM
MaximilianGlas
The documentation tells me how I have to deploy a configuration file for a user by putting it into the user directory. But what if I want to have it for all users on a machine? I do not want to deploy it in all user folders.
Is there a different folder where configurations could be deployed or am I able to define a custom folder for this?
Kind regards,
Max
by Anonymous User
Not applicable
Hello Max -
The documentation you referenced suggests that Configurations can be located in a "well-known folder", just like Add-Ins. So, you should be able to locate your Configuration file in such a directory, perhaps a secure, shared network directory, for use by your intended users.
For ArcGIS Pro Add-ins, you can define a "well-known folder" using the Backstage > Add-In Manager > Options resource.
Good Luck!
+ bill
UmaHarano
Here is the registry key to set in order to define Configurations well known folders for all users on the machine:
Configuration Folders
