'Add Database Connection' not working
1800
5
04-08-2019 05:59 AM
HeatherScroggins
I just upgraded one of my servers to 10.5.1 from 10.2.1 and now I can't get the 'Add Database Connection' to work. I've tried it in both ArcMap and ArcCatalog and nothing happens when you double click 'Add Database Connection'. I've tried to search on possible issues but have found nothing. Has anyone else run into this? What could be causing this?
MichaelVolz
Esteemed Contributor
Maybe try to recreate your Normal.mxt and Normal.gxt to see if that solves the issue.
Are there any other features of ArcMap/ArcCatalog 10.5.1 that are not working for you?
If so, you might want to try a repair.
If that does not work maybe a re-install.
MichaelVolz
Are you getting this dialog box to show up when you double-click Add Database Connection in ArcCatalog?
HeatherScroggins
No, I get nothing at all when I double click 'Add Database Connection'.
MichaelVolz
HeatherScroggins
I did a repair and everything seems to be working like it should. I don't know why I didn't think of that before. Thanks for your help!
JakeSkinner
Esri Esteemed Contributor
Hi Heather,
Are you able to successfully execute the Create Database Connection tool in Toolbox?
