Which commands trigger Customization Filters
994
03-26-2019 01:12 PM
serbanmarin1
I'm able to use a CustomizationFilter to run my custom addin code when the user right clicks on a Layer in the Contents Pane and clicks on "Zoom to Layer".
I try to do the same only this time I select an object on the map which opens the Pop-up Pane and then right click the object and try to "Zoom To" that object. Is the "Zoom To" not a command like the other? Is there a way to execute custom addin code instead of the default "Zoom To" behavior?
KoryKramer
Esri Community Moderator
UmaHarano
Hi
Are you referring to the Zoom to button at the bottom of the Pop up - screenshot below:
The only way to customize the Zoom to on the Pop-up is to provide your own pop-up.  Here is a sample that shows you how to implement this:  Custom Pop-up.
Note: You cannot replace Pro's pop-up.
Uma
