Loading survey from web Message Error
3086
9
03-25-2019 10:25 AM
HaroldHerrera1
Hi Survey Team.
Today I get this message error when access the survey from web. Do anyone know what's the problem?
Last week we didn't have problem
by Anonymous User
Not applicable
Hello Harold,
Have you uploaded this from Survey123 Connect? If so, what version of Survey123 Connect are you working with?There is a bug that has been logged and fixed in version 3.1. This bug produces the same error message that you are seeing. BUG-000115443: When the Read-Only property is set to Yes in a Surve..
If you are to upgrade to the latest version and republish, are you still receiving the error message?
Thank you,
Luba
HaroldHerrera1
Hi Luba,
Have you uploaded this from Survey123 Connect? Yes,
what version of Survey123 Connect are you working with? 3.3.51
About this bug, my survey doesn't have Read-only = Yes on selections question, BUT It has several Hidden question whit Read-only=Yes, It's possible another bug?
by Anonymous User
Not applicable
Hi Harold,
Would you be able to send the form? Either through this post or personally to my inbox. I can take a look at it and see if it's reproducible.
Best,
Luba
HaroldHerrera1
How can I send to your inbox?
HaroldHerrera1
Hi Luba Hristova
Thanks!
by Anonymous User
Not applicable
Hi Harold,
I attempted to send an inbox message yesterday, I'm not sure if you saw it. I'll take a look at the form.
by Anonymous User
Not applicable
Hi Harold,
A few different things that I have noticed.
Comentarios de Ing Sitio, isn't editable even in the Survey123 Connect application. When I go into the browser I click OK to the error message and then am not able to edit only Comentarios. I did a quick test and removed all Commentarios de Ing Sitio and this was successful without producing any errors in the browser.
At first, I thought it could be multiline predictivetext that is causing the issue but Observaciones is still in the form without causing any errors. Is there anything else in particular to Commentarios de Ing Sitio ?
HaroldHerrera1
Dear Luba
Thanks for your comments, I just erase the parameters in the "appearance" field and works fine!
by Anonymous User
Not applicable
Happy to hear that!
Best,
Luba
