Yeah using it as a pulldata sheet to perform some calculations based off survey selections. I thought that may have been the problem so I went through and removed everything even spaces, still same situation of crashing.
I have found that after successfully launching the survey if I move the file back into the media folder it will perform as normal. This is causing some real head scratching for myself, I even uninstalled/reinstalled Connect.
