Enable Time Settings of Feature Service
2462
03-08-2019 02:34 AM
KarstenRank
Hi there,
is it possible to enable to the "Time Settings" of a Feature Service with the Python API?
Thanks for your help
Karsten
KarstenRank
Find the solution:
  • first create a token
  • updateServiceDef
def updateServiceDef(token):
    ''' use this to update feature service max record count '''
    updateServiceDefURL = 'https://services2.arcgis.com/.../ArcGIS/rest/admin/services/.../FeatureServer/0/updateDefinition'
    params = {
      'updateDefinition': {"timeInfo" : {"startTimeField" : "DateTimeField1", "endTimeField" : "DateTimeField2"}},
        'async': 'true',
      'token': token,
      'f':'json'
    response = requests.post(updateServiceDefURL, data=params, verify=True)
KarstenRank
Find the solution:
  • updateServiceDef
    params = {
        'async': 'true',
      'token': token,
      'f':'json'
ThomasParisi
You should be able to do this with manager.update_definition() as well
lyr = gis.content.get('{your Feature Layer item id}').layers[0]
lyr.manager.update_definition({
  "timeInfo": {
    "startTimeField": "{your Start date/time field}",
    "endTimeField": "{your End date/time field}"
https://developers.arcgis.com/rest/services-reference/online/update-definition-feature-layer-.htm - This reference has plenty of other examples for Service Definition updates you can make with this function.
