Integer data display on Item page
1431
03-05-2019 10:25 AM
GaryBowles1
I have a hosted feature service being used to collect data from Survey123. We have a 5 digit code for all of our wells that is just a 5 digit code. It is not 50,006 or 32,348 they are 50006 and 32348. When i look at the data on the item page in Portal, the data is shown with the thousands comma. Is there a way to have the data not show the thousands comma?
--gary
Tags (3)
by Anonymous User
Not applicable
Hi Gary,
To get the code to display without the Thousand separator, we can configure the display in the "Configure Pop-up" tool. This can be access through the Table of Contents in a Web Map or in the Visualization tab in Item details (image below).
Steps to remove the Thousand Separator:  Open Configure Pop-up through Web Map or Visualization Tab > Click Configure Pop-up > Select the Code Field > Uncheck "Use 1000 Separator".
Hope this helps.
GaryBowles1
Claire,
Perfect. Thanks.
--gary
