Hiding fields in web service published via ArcGIS Pro
1091
03-03-2019 04:17 AM
MartinSirkovsky1
Hi.
I am starting to use ArcGIS Pro for publishing a services to ArcGIS Server. I am publishing to Portal. The data I am publishing are stored in DBMS and published as referenced (not hosted on the hosting server).
I have prepared my map in ArcGIS Pro and hid the fields which I do not want to make available in the service. However, after publishing all the fields are accessible in the service. I have never experienced this in ArcMAP.
The ESRI representative for our country suggested to use CREATE DATABASE VIEW tool. However, I doubt that this is a solution.
I guess there are many of you publishing services via ArcGIS Pro and hiding some of the fields. Is this working for you, or are you using a "create database view" tool to hide fields?
The version of ArcGIS Pro I am using is 2.3.0 and I am publishing to Portal 10.6.1.
Kind regards
Martin
Tags (1)
