Launchpad theme - Query widget result symbology
775
02-21-2019 05:33 AM
Nicole_Ueberschär
I am using the query widget within a launchpad themed web application (online web app builder). Although I configured the widget to use the symbology from the layer it only takes it partly (left picture):
I can understand if the symbology is too complicated for the query widget to combine colors and ring sizes but at least I would expect that it would take over the ring categories. Is there a way I could specify this symbology (or at least taking over the ring categories) in the json directly? The symbology is defined inside the feature service.
EDIT: Interestingly this worked well in a different version of the same app that uses a different web map with a different feature service but both feature services are using the same symbology. (right picture)
