Setting Label Class Language - ArcGIS Pro
2648
02-05-2019 01:25 PM
OliverCoudert
How can I set the Language for a Label Class from Python?  The code below works only if the language has been manually set to Python.  I would like to be able to set the language from within the code.
Edit: Asked a different way, is there a way to determine what the current setting is for Language in the Label Class?  With this information, the returned expression format can match the current Language setting.
aprx = arcpy.mp.ArcGISProject('CURRENT')
m = aprx.listMaps()[0]
lyr = m.listLayers()[0]
if lyr.supports('SHOWLABELS'):
    lyr.listLabelClasses()[0].expression = '\'<FNT name="Arial" size="8">\' + str([targetMap_STATEFP]) + \'</FNT>\''
    lyr.listLabelClasses()[0].visible = True
m.listLayers()[0].showLabels = True
2 Solutions
WendyHarrison
Hi Oliver,
At Pro 2.3 it is not possible to determine the parser or change it using ArcPy.  We are working on these items for upcoming releases.
thanks
Wendy
WendyHarrison
Hi Aneta
It's not available through the arcpy.mp api, but there is a workaround you can use through the cim module.
Help topic: https://pro.arcgis.com/en/pro-app/arcpy/mapping/python-cim-access.htm
Video: https://www.youtube.com/watch?v=8wgt8bKD0Ww&feature=youtu.be
The change parser expression code below is also in the help topic link above.
p = arcpy.mp.ArcGISProject('current')
m = p.listMaps('Map')[0]
l = m.listLayers('States_WithRegions')[0]
l_cim = l.getDefinition('V2')
lc = l_cim.labelClasses[0]
lc.expressionEngine = 'Python' #From 'Arcade'
lc.expression = '[STATE_NAME]' #From '$feature.STATE_NAME'
l.setDefinition(l_cim)
WendyHarrison
Hi Oliver,
thanks
Wendy
anyry
is it this possible in current version Pro?
WendyHarrison
Hi Aneta
