I want to clip the elevation data (3DEM) downloaded from USGS website. The raster-clip tool "Clip (data management)" in the Arcgis Pro works very well. However, I cannot clip it using the python function "arcpy.Clip_management()" .
The error report that the raster file is not exist or not support. I have tried different ways to read it, such as:
~grdn39w075.tif/Band_1 This is used by the Clip tool in Arcgis Pro ~grdn39w075.tif_Band_1 ~grdn39w075/Band_1
None of them can read the 3DEM file successfully.
Please let me know if you have any solutions. Thanks.
Python code:
in_raster= "~/Elevation/Tiles/grdn42w075.tif/Band_1"for i in range(0,9): buffer = shp_list[i] out_id=num_buffer=re.findall('\d+', shp_list[i]) out_path="C:/Users/zhangx24/Desktop/LUR_DM/GIS/Elevation/n42w75/" arcpy.Clip_management(in_raster,buffer,"n42w75_"+ out_id[1],"~/Documents/ArcGIS/Projects/LUR/LUR.gdb","99999","ClippingGeometry", "MAINTAIN_EXTENT")
You path is a bit convoluted and long, it is preferable to save rasters as a *.tif file in a folder, have you tried that?
