How to determine if a FeatureClass is compressed in a File GeoDatabase?
1969
01-25-2019 07:58 AM
DuncanHornby
MVP Notable Contributor
Hopefully a nice simple question? I've just upgraded to ArcGIS Pro 2.3 and compressed some FeatureClasses in a FIle GeoDatabase. I was wondering  how can you tell they are compressed within the Pro environment? I could see no visual clue or when looking at the FeatureClass properties see any text stating it has been compressed.
Am I having a Friday "moment" and have simply missed some obvious indicator?
MarisaClaggett
Hi duncan,
If you right click the feature class in Pro and go to Manage, there should be an option to uncompress or compress.  If only uncompress is an option, then the feature class is compressed.  However, I could not find any other visual indication in the geodatabase.  Hope that helps!
Marisa
DuncanHornby
I was hoping I had missed some sort of visual clue rather than the need for right clicking on a featureclass and checking the state of the context menu. In ArcCatalog when you view the contents of a geodatabase, any compressed featureclass have the word compressed after them. It would be nice to see Pro do something similar.
DanPatterson_Retired
Analogous to trying to run
Compress File Geodatabase Data—Data Management toolbox | ArcGIS Desktop
and see if the fc shows up as a candidate in the list
