Widget Open and Close
3054
01-31-2019 01:50 AM
kawishabbas
Hi
I am using arcgis api 4.10 and have a problem that i want to close first widget whenever click on second widget. i have attached file and code which is not running is mention below.
var DistanceExpand = watchUtils.pausable(distancemeasurement, "expanded", function(newValue, oldValue){
if(newValue === true){
DistanceExpand.pause();
setTimeout(function(){
printExpand.resume();
layerlistExpand.resume();
legendExpand.resume();
galleryExpand.resume();
}, 100);
}else{
DistanceExpand.resume();
if(print.expanded){
print.collapse();
if (layerlist.expanded) {
layerlist.collapse();
if (legend.expanded) {
legend.collapse();
if (gallery.expanded) {
gallery.collapse();
var printExpand = watchUtils.pausable(print, "expanded", function(newValue, oldValue){
printExpand.pause();
}, 100);
}else{
if(distancemeasurement.expanded){
distancemeasurement.collapse();
legend.collapse();
gallery.collapse();
var layerlistExpand = watchUtils.pausable(layerlist, "expanded", function(newValue, oldValue){
layerlistExpand.pause();
}, 100);
}else{
layerlistExpand .resume();
if (print.expanded) {
print.collapse();
legend.collapse();
gallery.collapse();
var legendExpand = watchUtils.pausable(legend, "expanded", function(newValue, oldValue){
legendExpand.pause();
}, 100);
}else{
print.collapse();
gallery.collapse();
var galleryExpand = watchUtils.pausable(gallery, "expanded", function(newValue, oldValue){
galleryExpand.pause();
}, 100);
}else{
print.collapse();
legend.collapse();
KellyHutchins
Esri Notable Contributor
You can use the group property on the Expand class to do that for you. Expand | API Reference | ArcGIS API for JavaScript 4.10
KellyHutchins
kawishabbas
Thank You Kelly one more question is that is there any possibility to add custom button on layerlist widget?
when click on button map goes to layer location/Extent
KellyHutchins
There's a sample here in the help that shows how to add custom actions to the layer list
LayerList widget with actions | ArcGIS API for JavaScript 4.10
