Regex for Only Numbers / letters
9073
01-30-2019 03:55 AM
PamelaLandy
hello, I'm trying to make a REGEX to validate an entry of only numbers from 0 to 9 of length 11 characters, following the YYY route
Phone Number Field
regex(${IDEPRONUMBER},'[0-9]\d{11}')
And another regex for Only letters
regex(${IDEPRONAME},'^[A-Za-z]')
But I get error
I do not want to use a mask  '9999999999', in case for number as mentioned in this development and errors can occur if someone has the regex can I share?
Tags (1)
Arturo_FranciscoAcosta_Bazán
Only letters :
regex(.,'^[A-Za-z]*$')  and string-length(.)= max num
Only numbers :
regex(.,'^[0-9]*$') and string-length(.)=max num
SarahHartholt
what would the expression be if I want the user to input numbers and special characters only, or only numbers and the characters ()- ? I have a phone number question in my survey and just noticed that someone has filled it in with letters
SarahHartholt
I solved it by adding a hidden field named 'character' and setting the default string to: ^[()-1234567890 ext.]+$
Then setting the constraint field for the phone number question to: regex(.,${characters})
with the help of this post:https://community.esri.com/thread/224012-regex-function-syntax
