ArcGIS Pro Export python
1750
5
01-29-2019 10:44 AM
CCWeedcontrol
I am trying to export a project to pdf.
With arcpy.mapping i had the following and worked
import arcpy, os, sys
mxd = arcpy.mapping.MapDocument("CURRENT")
folder = os.path.dirname(mxd.filePath) # H:/GIS_Data
fullfilename = os.path.basename(mxd.filePath) # junk.mxd
filename = os.path.splitext(fullfilename) # [junk, mxd]
name = filename[0] # junk
pdfname = name + '.pdf' # junk.pdf
outpdf = folder + "/" + pdfname # H:/GIS_Data/junk.pdf
arcpy.mapping.ExportToPDF(mxd, pdfname, "PAGE_LAYOUT",0 ,0 ,"210")
I am attempting to do this with ArcGIS Pro arcpy.mp and have the following but having a hard time getting it started.
I get AttributeError: 'str' object has no attribute 'listLayouts' with the following.
p = arcpy.mp.ArcGISProject("CURRENT").filePath
l = p.listLayouts()[0]
l.exportToPDF(R"C:\temp\Ex1_WA.pdf", 'CURRENT',0 ,0 ,"210")
DanPatterson_Retired
ilePath
(Read Only)
Returns a string value that reports the fully qualified project path and file name.
So it should work unless you are not running it from with a toolbox in an open session of Pro or from Pro's python window.
To test, just throw the actual path in there, because 'CURRENT' doesn't seem to be returning anything other than a string (perhaps None)
CCWeedcontrol
I was trying to run it in Pro's Python window, is this not allowed?
can you not set the os.path.dirname so you won't have to give the full path name?
perhaps you are shortcutting
pth = p.filePath
the first line, assuming it works, should return a project
the second line returns the path to the project
the way you had it
just returns the path to the project and not the actual project which is needed later on.
CCWeedcontrol
I got it to work the the following, thanks for the help.
folder = os.path.dirname(p.filePath)
fullfilename = os.path.basename(p.filePath)
name = filename[0]
l.exportToPDF(pdfname,resolution = 300)
so not getting the aprx object was the issue then.
with the extra path stuff cut out
