Why are the layout text symbol options greyed out?
3207
01-22-2019 10:14 AM
RichardCornell1
Um, any ideas why the text symbol options are greyed out when trying to add a title to the layout? The map frame is not activated. I have not experienced this before, so probably something simple. Using ArcGIS Pro 2.2.4.
Richard
Tags (3)
TomBole
Richard,
I'm guessing you have a Map Frame selected in the layout. These options are grayed out because they are not applicable with the current selection - Map Frame.  In order to add a title you will need to insert a text element.
For a title I would recommend using "Text".
This option is based on a point text symbol and allows you to manually resize the element by dragging the selection handles.
For more information see Edit text—Layouts | ArcGIS Desktop.
Hope this helps,
Tom
TomBole
Richard,
Hope this helps,
Tom
RichardCornell1
I figured it was something simple I overlooked. Thanks for providing an in depth explanation!
Richard
TomBole
Glad to help!
Tom
