LocationDataSource Crash - Xamarin
874
01-18-2019 08:38 AM
JeremyBridges
We've noticed a crash come through our telemetry channels that looks to be entirely within the esri stack (below). We enable the location dot by just setting MapView.LocationDisplay.IsEnabled to true. Any direction would be helpful. Though, perhaps this is just good info for the Runtime team for a possible fix.
SIGABRT: Invalid argument: location data source has been started.
  • ArcGISException.HandleCoreError (RuntimeCoreNet.GeneratedWrappers.CoreError error, System.Boolean throwExceptionC:\daily_r\api_xam\dotnet\api\src\Esri.ArcGISRuntime\Esri.ArcGISRuntime.Shared\ArcGISExceptions.cs:75
  • Interop.CheckError (System.IntPtr errorHandle, System.Boolean throwOnFailure, System.Runtime.InteropServices.GCHandle wrapperHandle) C:\daily_r\api_xam\dotnet\api_generated_interop\managed_wrappers\Interop.cs:104
  • CoreLocationDataSource.HandleStart (RuntimeCoreNet.GeneratedWrappers.CoreClientReference userDefinedError) C:\daily_r\api_xam\dotnet\api_generated_interop\managed_wrappers\CoreLocationDataSource.cs:470
  • LocationDataSource+<RuntimeCoreNet-GeneratedWrappers-ICoreCallback_LocationDataSource_StartCallback-StartCallback>d__19.MoveNext () C:\daily_r\api_xam\dotnet\api\src\Esri.ArcGISRuntime\Esri.ArcGISRuntime.Shared\Location\LocationDataSource.cs:172
  • AsyncMethodBuilderCore+<>c.<ThrowAsync>b__6_0 (System.Object state) /Library/Frameworks/Xamarin.iOS.framework/Versions/12.2.1.12/src/Xamarin.iOS/mcs/class/referencesource/mscorlib/system/runtime/compilerservices/AsyncMethodBuilder.cs:1023
  • NSAsyncSynchronizationContextDispatcher.Apply () /Library/Frameworks/Xamarin.iOS.framework/Versions/12.2.1.12/src/Xamarin.iOS/Foundation/NSAction.cs:178
  • (wrapper managed-to-native) UIKit.UIApplication.UIApplicationMain(int,string[],intptr,intptr)
  • UIApplication.Main (System.String[] args, System.IntPtr principal, System.IntPtr delegate) /Library/Frameworks/Xamarin.iOS.framework/Versions/12.2.1.12/src/Xamarin.iOS/UIKit/UIApplication.cs:79
  • UIApplication.Main (System.String[] args, System.String principalClassName, System.String delegateClassName) /Library/Frameworks/Xamarin.iOS.framework/Versions/12.2.1.12/src/Xamarin.iOS/UIKit/UIApplication.cs:63
  • Application.Main (System.String[] args) /.../Main.cs:9
