Issue Combining ProSnippets for arcgis pro sdk
2485
01-17-2019 09:53 AM
KarenRobbins
I am trying to use two ProSnippets within a SINGLE ArcGIS Pro tool and need help.  Here are the two snippets, but I cannot seem to make them both work within a single tool.  I did this within an Add-In tool in ArcGIS Desktop, but I'm not sure what is going on with Pro.  Can anyone steer me in the right direction.  I want a single click to give me  Coordinates AND access to the underlying layers.  (Once coded, I don't really need the info in MessageBoxes)
Create a tool to the return coordinates of the point clicked in the map
internal class GetMapCoordinates : MapTool
    protected override void OnToolMouseDown(MapViewMouseButtonEventArgs e)
        if (e.ChangedButton == System.Windows.Input.MouseButton.Left)
            e.Handled = true; //Handle the event args to get the call to the corresponding async method
     protected override Task HandleMouseDownAsync(MapViewMouseButtonEventArgs e)
    {        return QueuedTask.Run(() =>
        //Convert the clicked point in client coordinates to the corresponding map coordinates.
        var mapPoint = MapView.Active.ClientToMap(e.ClientPoint);
            ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show(string.Format("X: {0} Y: {1} Z: {2}",                mapPoint.X, mapPoint.Y, mapPoint.Z), "Map Coordinates");
Create a tool to identify the features that intersect the sketch geometry
internal class CustomIdentify : MapTool
{    public CustomIdentify()
        IsSketchTool = true;
        SketchType = SketchGeometryType.Point;  //In the Snippet this is Rectangle, I just want it the point.
         //To perform a interactive selection or identify in 3D or 2D, sketch must be created in screen coordinates.
        SketchOutputMode = SketchOutputMode.Screen;
     protected override Task<bool> OnSketchCompleteAsync(Geometry geometry)
            var mapView = MapView.Active;
            if (mapView == null)
                return true;
         //Get all the features that intersect the sketch geometry and flash them in the view.
        var results = mapView.GetFeatures(geometry);
            mapView.FlashFeature(results);
         //Show a message box reporting each layer the number of the features.
        MessageBox.Show(
            String.Join("\n", results.Select(kvp => String.Format("{0}: {1}", kvp.Key.Name, kvp.Value.Count()))),
            "Identify Result");
            return true;
CharlesMacleod
As your tool is using point as its sketch type then cast the Geometry input parameter in the OnSketchCompleteAsync callback to MapPoint and you have it.
MapPoint mp = (MapPoint)geometry;
KarenRobbins
It works, (THANK YOU!) except it's giving me screen coordinates instead of State Plane coordinates. (When I ran it individually it gave me the correct coordinates)
I'm guessing this has to do with this:
Any ideas?
CharlesMacleod
correct. Change SketchOutputMode to map.
KarenRobbins
That worked.  Thanks again.
Just curious, then why does it say "//To perform a interactive selection or identify in 3D or 2D, sketch must be created in screen coordinates." if the identify still works?
