Calculate and Summarize features in Web App Builder
4525
6
01-15-2019 07:38 AM
JohnBrockwell
I am trying to understand the widgets available with the Web App Builder. I have Geo-enriched population data in a polygon feature layer. I like users to select polygons (Select Widget) and then have the selection summarize (Summary Widget) the totals of the selection. I tried using the summary widget but that calculates based on the map extent. Does anyone have any experience with this? Does anyone know if there is a more appropriate widget to use?
Web App Builder Example
John T. Brockwell, GISP
NYC Arc
Piyali KunduLauri Dafner
Tags (1)
RobertScheitlin__GISP
John,
  My custom eSearch widget allows you to add a summed field(s) and make a graphical selection on the map.
John,
JohnBrockwell
Hi Robert,
Thank you for the recommendation. I went ahead and tested but I hit a snag. It doesn't recognize my service when I edit Enhanced Search widget. Search URL Field Required, Included Fields is Empty.
I entered the following URL:
https://ArcGISServerURL.DOMAIN/arcgis/rest/services/PopulationData/FeatureServer
I can't get around this one. Wondering if I am missing a step?
Thank you again,
You are missing the layer id in your url (i.e. /0).
JohnBrockwell
Thanks. That fixed it for me. Sometimes you need a number at the end sometimes you don't.
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
Krocha
How do we obtain this customized widget? I don't see it for an option.
