Backup Geodatabase but without Rasters
535
01-09-2019 10:56 AM
DiegoLlamas
I have a SQL Server geodatabase, in this geodatabase I also have several rasters in it. Using automatic backup option it do a full backup with the 250 GB of rasters. Is it possible to do a full backup but telling SQL do not backup my Rasters?
Thank you very much for your help!
Diego Llamas
George Thompson's Blog
George_Thompson
Esri Notable Contributor
You could look into SQL Server Import and Export tools.
Exporting Selected tables from a SQL Database – Microsoft Team Foundation Server Support
Start the SQL Server Import and Export Wizard - SQL Server | Microsoft Docs
You would have to make sure that you exclude all the appropriate raster tables. This may be a mess.
Can you export those rasters to disc then reference them in a mosaic dataset? If you can do that, it would probably have quite a few benefits for the geodatabase.
--- George T.
MichaelVolz
Esteemed Contributor
I would concur with George Thompson as my org used to have rasters in SDE, but we have moved them to disc and reference the files in a Raster Mosaic Dataset.
Are you currently using the Image Server role of ArcGIS Enterprise?
Asrujit_SenGupta
