Dry Cleaner ESRI icon
1027
5
01-02-2019 07:00 AM
CynthiaJones
Hi, I am trying to find an appropriate dry cleaner icon to use on a web map.   The best icon so far is a washer and dryer, which isn't really what is needed, as it dry cleaners do not use washer and dryers.  If you have found a suitable icon (preferably ESRI), please respond.  Thank you!
AdrianWelsh
MVP Honored Contributor
Cynthia,
I can't say I have seen one from Esri but something like this should work, I would think:
Image result for dry cleaner icon
CynthiaJones
Adrian,
I really like this and did see it on the internet.  Perhaps we will need to create something, as I cannot find an ESRI one either.
Thanks!
by Anonymous User
Not applicable
Hi Cynthia,
I don't see a dry cleaning symbol from Esri either. The closest I found might be the Department Store icon the ArcGIS Explorer Style:
Here's also a link to the ArcGIS Symbol Library. Though this is very old, it might be a good document to look through, just to check?
I hope that helps! If I find anything else, I'll pass it along!
-Lauren
CynthiaJones
Thank you Lauren,
I like the department store clothing, but it may be too complex.  I have already looked through and searched through each of the symbols in the ESRI Library.
Thanks again!
JacobBoyle412
I'd take a look at: Noun Project - Icons for Everything
Jacob is a Sr. Solution Architect for Esri Professional Services and loves conservation planning, woodworking, LEGO, and his dogs.
