Another value ( NA) in Select Multiple option
2082
12-26-2018 02:14 PM
PamelaLandy
I want to place a multiple option select_multiple, but that contains the value: "NA - no previous value".
This value should exclude (or eliminate) another option marked within the other options. Is this possible in the multiple selection??
Currently the option NA appears added to the others which generates an inconsistency in my results.
Jim-Moore
Hi Pamela
There isn't a way to do this with a select_multiple question; all responses to a select_multiple are stored together in a comma-separated string. In your survey, would it be feasible to include a question preceding the select_multiple (e.g. "Is there a previous value?" Yes/No) that controls whether the user sees the select_multiple (using the relevant column) and/or sets a default for the select_multiple?
Some handy general info here: https://community.esri.com/groups/survey123/blog/2017/08/30/understanding-multiple-choice-questions-...
Jim
SoporteOSNG
Thanks Jim
Jim-Moore
Hi Pamela
Another option would be to apply a constraint to the select_multiple, to check if more than one answer is selected when NA is selected. For example:
if(selected(${question}, 'NA') and count-selected(${question}) > 1, false(), true() )‍
You could then add a constraint message to explain that no other selections are allowed when NA is selected.
