DGrid error - not refreshing
1691
12-22-2018 12:02 PM
KarenEllett
Since the feature table widget isn't ready yet, I'm using dgrid to display results of a query, as show in the "highlight features by geometry" example.  However it only works when I do a unique search.  If I do a search and it brings back feature 1, 2 and 3, then the grid shows.  I can do a second search, and it bring back features 3, 4 and 5, and the grid shows.  But if I redo the first search, and it gets the same result set - features 1, 2 and 3 - then it fails, and gives the error "TypeError: Cannot read propery 'element' of undefined, at _StoreMixin.js:2; which implies the error has to do with the datastore.  I've tried resetting the datastore, setting it to a blank array then back to the result set, etc; nothing works.  Does anyone have any ideas?  Code below:
function populateResultGrid(resultArray){
   document.getElementById("gridDisplay").style.display = "block";
   document.getElementById("featureCount").innerHTML = "<b>Showing attributes for " + resultArray.length + "    features</b>"
   require([
      "dgrid/OnDemandGrid",
      "dojo/store/Memory",
      "dstore/legacy/StoreAdapter",
      "dgrid/Selection"
   function(OnDemandGrid, Memory, StoreAdapter, Selection){
      var dataStore = new StoreAdapter({
         objectStore: new Memory({
         idProperty: "AssetID"
   dataStore.objectStore.data = resultArray;
   var grid = new(OnDemandGrid.createSubclass([]))({
      columns: getColumns()
   }, "grid")
   grid.set("collection", dataStore);
   grid.refresh();
RobertScheitlin__GISP
Karen,
  Here is a sample that I use and I have never had the issue:
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>QueryTask - 4.10</title>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
      overflow: hidden;
    #viewDiv.withGrid {
      height: 65%;
    .esri-widget {
      padding-left: 8px;
      padding-right: 4px;
    #paneDiv {
      position: absolute;
      top: 10px;
      left: 62px;
      padding: 0 12px 0 12px;
      background-color: rgba(0, 0, 0, 0.5);
      color: white;
    #gridDisplay {
      position: absolute;
      bottom: 0;
      left: 0;
      height: 35%;
      background-color: white;
      border-color: grey;
      width: 100%;
      font-family: "Avenir Next W00", "Helvetica Neue", Helvetica, Arial, sans-serif;
      font-size: 14px;
      display: none;
    #gridDisplay {
      z-index: 80;
    .info {
      line-height: 20px;
      padding-left: 5px ! important;
    .dgrid-header,
    .dgrid-header-row {
      background-color: #eee;
      color: #57585A;
    .dgrid-row-even {
      background-color: #F7F8F8;
    .dgrid-row-odd {
      background-color: #EFEFEF;
    .dgrid-selected {
      background: #B4DAF5;
    .dgrid-row {
      border: none
  </style>
  <link rel="stylesheet" href="https://js.arcgis.com/4.10/esri/css/main.css">
  <script src="https://js.arcgis.com/4.10/"></script>
  <script>
    require([
        "esri/Map",
        "esri/views/MapView",
        "esri/widgets/Home",
        "esri/widgets/Legend",
        "esri/widgets/Search",
        "esri/layers/GraphicsLayer",
        "esri/Graphic",
        "esri/tasks/QueryTask",
        "esri/tasks/support/Query",
        "dojo/_base/array",
        "dojo/dom",
        "dojo/on",
        "dgrid/extensions/ColumnHider",
        "dgrid/Selection",
        "dojo/_base/declare",
        "dojo/dom-class",
        "dojo/domReady!"
      function(
        Map, MapView, Home, Legend, Search, GraphicsLayer, Graphic, QueryTask, Query, arrayUtils, dom, on,
        OnDemandGrid, ColumnHider, Memory, StoreAdapter, Selection, declare, domClass
        let map, view, grid;
        let RUrl = "https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/Prominent_Peaks_US/FeatureServer/0";
        let FUrl = "https://services.arcgis.com/V6ZHFr6zdgNZuVG0/ArcGIS/rest/services/2015_06_26_active_fires_USA_contig...";
        let gridFields = ["OBJECTID", "RANK", "MTN_PEAK", "STATE",
          "ELEV_ft", "ELEV_m" ,"PROMINENCE_ft" ,"PROMINENCE_m"
        // create a new datastore for the on demandgrid
        // will be used to display attributes of selected features
        let dataStore = new StoreAdapter({
            idProperty: "OBJECTID"
        const gridDis = document.getElementById("gridDisplay");
        // Define the popup content for each result
        const popupTemplate = { // autocasts as new PopupTemplate()
          title: "{MTN_PEAK}, {STATE}",
          fieldInfos: [{
            fieldName: "ELEV_ft",
            label: "Elevation (feet)",
            format: {
              places: 0,
              digitSeperator: true
            fieldName: "ELEV_m",
            label: "Elevation (meters)",
            format: {
              places: 0,
            fieldName: "PROMINENCE_ft",
            label: "Prominence (feet)",
            format: {
              places: 0,
            fieldName: "PROMINENCE_m",
            label: "Prominence (meters)",
            format: {
              places: 0,
            fieldName: "ISOLATION_mi",
            label: "Isolation (miles)",
            format: {
              places: 0,
            fieldName: "ISOLATION_km",
            label: "Isolation (km)",
            format: {
              places: 0,
          content: "<b><a href='https://en.wikipedia.org/wiki/Topographic_prominence'>Prominence:</a>" +
            "</b> {PROMINENCE_ft} ft ({PROMINENCE_m} m)" +
            "<br><b>Prominence Rank:</b> {RANK}" +
            "<br><b>Elevation:</b> {ELEV_ft} ft ({ELEV_m} m)" +
            "<br><b><a href='https://en.wikipedia.org/wiki/Topographic_isolation'>Isolation:</a>" +
            "</b> {ISOLATION_mi} mi ({ISOLATION_km} km)"
        const popupTemplate2 = { // autocasts as new PopupTemplate()
          title: "{TRACK}",
          fieldInfos: [{
            fieldName: "TRACK",
            label: "Track"
            fieldName: "BRIGHT_T31",
            label: "Brightness",
            format: {
              places: 0,
            fieldName: "CONFIDENCE",
            label: "Confidence"
            fieldName: "SCAN",
            label: "Scan",
            format: {
              places: 0,
          content: "Brightness: {BRIGHT_T31}" +
            "<br><b>Confidence:</b> {CONFIDENCE}" +
            "<br><b>Scan: {SCAN}"
        let resultsLayer = new GraphicsLayer();
        let resultsLayer2 = new GraphicsLayer();
        let qTask = new QueryTask({
          url: RUrl
        let qTask2 = new QueryTask({
          url: FUrl
        let params = new Query({
          returnGeometry: true
        map = new Map({
          basemap: "streets",
          layers: [resultsLayer, resultsLayer2]
        view = new MapView({
          map: map,
          container: "viewDiv",
          zoom: 11,
          popup: {
            dockEnabled: true,
            dockOptions: {
              position: "top-right",
              breakpoint: false
        function createGrid(fields) {
          var columns = fields.filter(function(field, i) {
            if (gridFields.indexOf(field.name) !== -1) {
              return field;
          }).map(function(field) {
            if (field.name === "OBJECTID") {
              return {
                field: field.name,
                label: field.name,
                sortable: true,
                // hidden: true
            } else {
              return {
                field: field.name,
                label: field.alias,
                sortable: true
          // create a new onDemandGrid with its selection and columnhider
          // extensions. Set the columns of the grid to display attributes
          // the hurricanes cvslayer
          grid = new(declare([OnDemandGrid, Selection, ColumnHider]))({
            columns: columns
          }, "grid");
          // add a row-click listener on the grid. This will be used
          // to highlight the corresponding feature on the view
          grid.on("dgrid-select", selectFeatureFromGrid);
        function selectFeatureFromGrid(event) {
          // close view popup if it is open
          view.popup.close();
          // get the ObjectID value from the clicked row
          var row = event.rows[0]
          var id = row.data.OBJECTID;
          // setup a query by specifying objectIds
          var query = {
            objectIds: [parseInt(id)],
            outFields: ["*"],
            returnGeometry: true,
            outSpatialReference: view.spatialReference
          if(wlayer.value === 'peaks'){
            qTask.execute(query).then(function(results){
              const graphics = results.features;
              // remove all graphics to make sure no selected graphics
              view.graphics.removeAll();
              // create a new selected graphic
              var selectedGraphic = new Graphic({
                geometry: graphics[0].geometry,
                symbol: {
                  type: "simple-marker",
                  style: "circle",
                  color: "orange",
                  size: "12px", // pixels
                  outline: { // autocasts as new SimpleLineSymbol()
                    color: [255, 255, 0],
                    width: 2 // points
              // add the selected graphic to the view
              // this graphic corresponds to the row that was clicked
              view.graphics.add(selectedGraphic);
          }else if(wlayer.value === 'fires'){
            qTask2.execute(query).then(function(results){
              const graphics2 = results.features;
                geometry: graphics2[0].geometry,
                symbol: {
                  style: "circle",
                  color: "orange",
                    width: 2 // points
        view.when(function() {
          view.ui.add("optionsDiv", "bottom-right");
          on(dom.byId("doBtn"), "click", doQuery);
          on(dom.byId("clrBtn"), "click", doClear);
        const attributeName = dom.byId("attSelect");
        const expressionSign = dom.byId("signSelect");
        const value = dom.byId("valSelect");
        const wlayer = dom.byId("lyrSelect");
        function doClear() {
          if(grid){
            dataStore.objectStore.data = {};
          resultsLayer2.removeAll();
          gridDis.style.display = 'none';
          domClass.remove("viewDiv", 'withGrid');
        function doQuery() {
          doClear();
          // Clear the results from a previous query
          resultsLayer.removeAll();
          params.where = attributeName.value + expressionSign.value + value.value;
            params.outFields = ["*"];
            qTask.execute(params)
              .then(getResults)
              .catch(promiseRejected);
            gridFields = ["OBJECTID", "BRIGHTNESS", "SCAN", "TRACK",
              "ACQ_DATE", "ACQ_TIME", "SATELLITE", "CONFIDENCE", "VERSION"
            params.where = 'BRIGHTNESS > 320';
            qTask2.execute(params)
              .then(getResults)
        function getResults(response) {
          let graphics = response.features;
          if (graphics.length > 0) {
            gridDis.style.display = 'block';
            domClass.add("viewDiv", 'withGrid');
              graphics.length.toString() + " features </b>"
          } else {
          createGrid(response.fields);
          // get the attributes to display in the grid
          var data = graphics.map(function(feature, i) {
            return Object.keys(feature.attributes)
              .filter(function(key) {
                // get fields that exist in the grid
                return (gridFields.indexOf(key) !== -1);
              // need to create key value pairs from the feature
              // attributes so that info can be displayed in the grid
              .reduce((obj, key) => {
                obj[key] = feature.attributes[key];
                return obj;
          // set the datastore for the grid using the
          // attributes we got for the query results
          dataStore.objectStore.data = data;
          var RResults = arrayUtils.map(response.features, function(
            feature) {
            feature.symbol = {
              color: "red",
              outline: {
                color: "black"
              feature.popupTemplate = popupTemplate;
              feature.popupTemplate = popupTemplate2;
            return feature;
            resultsLayer.addMany(RResults);
            resultsLayer2.addMany(RResults);
          view.goTo(RResults);
        function promiseRejected(error) {
          console.error("Promise rejected: ", error.message);
        var homeBtn = new Home({
          view: view
        }, "homeDiv");
        var legend = new Legend({
          view: view,
          layerInfos: [{
            url: RUrl
        legend.startup();
        view.ui.add(legend, "bottom-left");
        var searchWidget = new Search({
          view: view
        view.ui.add(searchWidget, {
  </script>
</head>
<body>
  <div id="viewDiv">
    <div class="esri-widget" id="optionsDiv">
      <h2>Prominent Peaks in the U.S.</h2>
      <select class="esri-widget" id="lyrSelect">
        <option value="fires">US Fires</option>
        <option value="peaks" selected>US Peaks</option>
      </select>
      <select class="esri-widget" id="attSelect">
        <option value="ELEV_ft">Elevation</option>
        <option value="PROMINENCE_ft" selected>Prominence</option>
      </select>
      <select class="esri-widget" id="signSelect">
        <option value=">">is greater than</option>
        <option value="<">is less than</option>
        <option value="=">is equal to</option>
      </select>
      <select class="esri-widget" id="valSelect">
        <option value="1000">1,000 ft</option>
        <option value="5000">5,000 ft</option>
        <option value="10000">10,000 ft</option>
        <option value="15000">15,000 ft</option>
        <option value="20000">20,000 ft</option>
      </select>
      <br>
      <br>
      <button class="esri-widget" id="doBtn">Do Query</button>
      <button class="esri-widget" id="clrBtn">Clear</button>
      <br>
      <br>
    </div>
    <div id="gridDisplay">
      <span class="info" id="featureCount"></span>
      <div id="grid"></div>
    </div>
  </div>
</body>
</html>
