Cannot create new Desktop geodatabase on SQL EXPRESS 2014
2663
7
12-20-2018 02:01 AM
AlessandroValra
I downloaded from myesri and installed SQL SERVER EXPRESS 2014 and enabled it spatially (all through the "Database Server Desktop" installer).
I have added some windows logins to my instance and granted them sysadmin privileges (via ArcCatalog).
From one of my sysadmin users I try to create a new Desktop gdb (via right click on the SQL EXPRESS instance in the catalog -> New Geodatabase). ArcMap is 10.4.1.
I named it "test" and then created it leaving all other parameters as defaults.
This is what I see:
However, it can't go on...
I am forced to shutdown ArcMap. I can then reopen ArcMap, see the gdb, but it is corrupted and I cannot use it.
In the server machine where I installed SQL EXPRESS I can go in the logs (C:\Program Files\Microsoft SQL Server\MSSQL12.SQLEXPRESS\MSSQL\Log), and here are some rows I see in ERRORLOG. The full log is attached.
2018-12-20 10:42:56.01 spid51      Starting up database 'test'.
2018-12-20 10:42:56.76 spid51      Setting database option RECOVERY to SIMPLE for database 'test'.
2018-12-20 10:43:25.63 spid54      Setting database option READ_COMMITTED_SNAPSHOT to ON for database 'test'.
2018-12-20 10:43:25.69 spid54      Starting up database 'test'.
2018-12-20 10:43:25.91 spid54      Setting database option ALLOW_SNAPSHOT_ISOLATION to ON for database 'test'.
2018-12-20 10:43:44.89 spid54      AppDomain 29 (master.sys[runtime].28) created.
2018-12-20 10:43:47.01 spid33s     AppDomain 29 (master.sys[runtime].28) is marked for unload due to memory pressure.
2018-12-20 10:43:47.01 spid33s     AppDomain 29 (master.sys[runtime].28) unloaded.
2018-12-20 10:44:15.20 spid54      AppDomain 30 (master.sys[runtime].29) created.
Specs of the server machine are:
Any idea how to make it work?
George_Thompson
Esri Notable Contributor
Usually errors related to this:
seem to be machine errors. I know that SQL Express will only use 1GB RAM and 1 CPU core, so what is the memory being used by the SQL instance when creating the GDB?
Is SQL Express 64 or 32 bit version?
--- George T.
AlessandroValra
George Thompson‌ Thanks for the feedback.
It is 64bit.
Don't know how to tell this...
From the task manager I can see the "never-to-be-finished"-SQL Server (SQLEXPRESS) process is taking about 70 MB, if this might be relevant.
George_Thompson
Thanks for that. It seems like the memory on the SQL instance is ok. I have not tested this with SQL Express 2014.
Did the installer you use come from Microsoft or Esri?
What is the version of SQL client being used? ArcGIS 10.4.x needs the ODBC 11 drivers installed.
--- George T.
AlessandroValra
Really appreciate your effort in solving the issue I am facing.
I have downloaded it from myesri.
I downloaded the ODBC 11 driver for version 10.4.1 from myesri and lanched the setup. Apparently, I had a previous version of the driver installed and the setup upgraded it.
Nevertheless, I still have this issue unfortunately.
George_Thompson
Ok, I would recommend that you contact technical support on this. It seems that there is something else going on. Not sure what.
--- George T.
AlessandroValra
George Thompson‌ I did it. Thank you so much for taking the time to helping me. Regards.
AlessandroValra
George Thompson‌ Sorry to bother again. While I am waiting for the support to handle my issue, I would like to ask you one more question if you know the answer: I did not specify I installed version 10.6.1 of Database Server (Desktop). Would this be the problem (meaning I am trying to create a geodatabase with a 10.4.1 ArcMap client on a 10.6.1 database server)?
I could not find an answer in these links:
ArcGIS client and workgroup or desktop geodatabase compatibility—Help | ArcGIS Desktop
Compatibility between ArcGIS clients and geodatabases in SQL Server—Help | ArcGIS Desktop
Many thanks in advance!
