Vector Tile Layer Not Rendering Correctly in ArcGIS API 4.10
1708
12-19-2018 04:58 AM
RaymondBaguio
After updating to version 4.10 a vector tile layer is not rendering correctly but working perfectly fine in version 4.8. Does anyone encountered this kind of problem? I there any solution/workaround for this? Hope anyone could help me on this.
Thanks.
UndralBatsukh
Hi there,
Can you share you VectorTileLayer url here?
RaymondBaguio
UndralBatsukh
Hi there,
I am sorry if I am following description of the issue. But I am not able to see the issue you are describing with 4.10 with vectortiles + the mapimagelayer you referenced.
Here is a codepen app that has topo vector tiles and the mapimagelayer you referenced: VectorTileLayer - 4.10
I do not see the issue you described.
RaymondBaguio
Hi Undral Batsukh‌
Thank you for your reply. The problem is the opacity. I removed the opacity and now it's working perfectly.
