Web AppBuilder not keeping custom changes when re-imported
1999
12-10-2018 12:03 PM
MichaelTorbett
I have an application that I built using the Web AppBuilder Developer's Edition. I downloaded and gave it to my web developer to customize the look of one widget for this particular app. He then sent it back to me and I deployed it to my server for access through AGOL. Everything has been working fine. However, now I need to make some additional changes. When I go to re upload the app to WebApp Builder, the widget that was customized reverts to it's default look and feel. The code that my web developer implemented is not holding even though it is still there. Any Idea what's causing this?  Everything has been done with WAB 2.10.
Michael
One thing to note: The widget I am referring to is the NearMe widget. We worked directly with it without making a copy or changing it's name. Not sure if this might be the problem.
RobertScheitlin__GISP
Michael,
    Customizing a default widget like the NearMe widget would definitely be the issue. When importing the app it will look at the widgets used in the app and if they are default widget it will just use the widget from the stemapp widgets directory and not attempt to import that widget from the imported app.
Michael,
MichaelTorbett
Thank you for the reply Robert. I had a feeling that was the problem. I've tried making a copy and renaming the widget (NearMeCustom).  I changed it's name in the manifest.json and in the Widget.js folder (baseClass: 'jimu-widget-nearmecustom' ,) .  However, the widget still displays as "NearMe" in the widget panel instead of "NearMeCustom." Am I missing something?
Michael,
   The widgets label is often set in the nls/strings.js file.
MichaelTorbett
Got it!. That's what I needed. Thank you for your help Robert. I've been looking everywhere for that.
