Null Error when generating report (beta) in Survey123
775
12-10-2018 02:59 AM
AdamCorcoran
I have a feature layer (>2,000 points) with several related tables used to conduct inspections via Survey123. I've set up a printing template (devised from the sample template), which pulls data from the related tables and produces a report.
The current workflow is:
This workflow has worked in the past. We've tried selecting multiple points, changing the template and uploading a new template with no luck.
Here's the error we're seeing: "An error occurred while generating report(s). [null]
If anyone has any feedback, I'd greatly appreciate it!
- Adam
JamesTedrick
Esri Esteemed Contributor
Hi Adam,
Could you share the XLS file and DOCX template so that we can attempt to reproduce?
