Generating new output names after each iteration
1887
12-06-2018 01:54 PM
Sam_Roodbar
Hello Everyone,
I'm trying to write a script that will take a look at a list of county boundaries and then take each boundary and use it as a mask on a raster so that I can do Extract By Mask. Ideally I would like to have the county names on the output but I cannot figure out a way to do that, but any unique name at this point would do. Here is the script that I use:
>>> import os
>>> import arcpy
>>> from arcpy import env
>>> from arcpy.sa import *
>>> env.workspace = "C:/Users/s/Desktop/S/test"
>>> inRaster = "escrec"
>>> counter = 1
>>> ctyList = arcpy.ListFeatureClasses ("*.shp")
>>> for shp in ctyList:
... out = arcpy.sa.ExtractByMask(inRaster,shp)
... out.save("C:/Users/s/Desktop/test/out/masked"+ counter)
... counter = counter+2
I tried using this counter thing but it doesn't work due to concatenate issue (str and numbers). Anyone has any suggestions or tricks that they have done? I tried setting the counter as my "ctyList" but since feature have .shp it doesn't allow that to save.
extract by mask‌ acrpy#
Sam_Roodbar
I worked out another way to do the same, much easier:
>>> import os
>>> import arcpy
>>> env.workspace = "C:\XXX"
>>> inRaster = "nlcdrecmosaic"
>>> for shp in ctyList:
... CtyName = shp.split('.')[0]
... out= arcpy.sa.ExtractByMask(inRaster,shp)
... out.save("C:\XXX\out\mskd"+ CtyName)
SteveLynch
out.save(r"C:\Users\s\Desktop\test\out\masked"+ str(counter) + ".tif")
Sam_Roodbar
Thank you, I tried it and it works but the names of outputs were strange.
I specified counter as 01001 (for the first county) but the outputs started 513!!
is there a way to have the name of the shp s for output?
DanPatterson_Retired
perhaps....
counter = 100
shp = "test.shp"
pth = r"C:\Users\s\Desktop\test\out\masked"
out = "{}\\{}{}.tif".format(pth, shp[:-4], counter)
out
'C:\\Users\\s\\Desktop\\test\\out\\masked\\test100.tif'
Sam_Roodbar
>>> import os
>>> import arcpy
>>> for shp in ctyList:
