Updating table fields from a raster file
2058
6
12-05-2018 03:08 AM
RenanBarroso
Hi there! I have some raster files in grid format with signed integer pixels in which I want to add some fields in their table then compute values with some formulas in the new fields. I managed to add the fields but I'm struggling with the second part. I tried with arcpy.da.UpdateCursor but it returns a RuntimeError: 'in_table' is not a table or a feature class. It seems clear for me that I can not use this function with raster file. Is there a way to compute the values directly in the raster or do I have to try a different approach? How?
The code is:
import arcpy as ap
import os
import random_function as rf # change name after
from arcpy.sa import *
if ap.CheckExtension('Spatial') == 'Available':
     ap.CheckOutExtension('Spatial')
else:
     print('Spatial Analyst extension is not available')
# Setting environments & paths
ap.env.workspace = os.path.join("D:\\", "master", "_thesis_data")
ap.env.scratchWorkspace = os.path.join(ap.env.workspace, "temp")
ap.env.overwriteOutput = True
inp_ws = ap.env.workspace
temp_ws = ap.env.scratchWorkspace
lu_folder = os.path.join(inp_ws, "lu")
lu_scenarios = []
for dirpath, dirnames, filenames in ap.da.Walk(lu_folder, datatype='RasterDataset'):
     for f in filenames:
          lu_scenarios.append(os.path.join(dirpath,f))
# Setting input data
climate = Raster("climate_c")
clim_soil = Raster("rc_climsoil_c")
tbl_uSOCr = os.path.join(inp_ws, "uSOCr.txt")
tbl_uSOCf = os.path.join(inp_ws, "uSOCf.txt")
tbl_uBCi = os.path.join(inp_ws, "uBCi.txt")
for (sc, lu_sc) in enumerate(lu_scenarios):
     lu = Raster(lu_sc)
     clim_lu = climate + lu
     soc_f1k = ReclassByTable(clim_lu, tbl_uSOCf, "id", "id", "soc_factor")
     soc_r1k = ReclassByTable(clim_soil, tbl_uSOCr, "id", "id", "soc_ref")
     soc_1k = (soc_f1k*soc_r1k)/1000
     bc_1k = ReclassByTable(clim_lu, tbl_uBCi, "id", "id", "bcs")
     tc_1k = (soc_1k + bc_1k)
     tc_1k_new_fields = ["tc", "tot_ha", "tot_cs"]
     for field in tc_1k_new_fields:
          ap.AddField_management(tc_1k, field, "FLOAT", 12, 4)
     with ap.da.UpdateCursor(tc_1k, "*") as cursor:
          tc_all_fields = [f.name for f in arcpy.ListFields(tc_1k)]
          VALUE, COUNT, tc, tot_ha, tot_cs = row[1], row[2], row[3], row[4], row[5]
                 for row in cursor:
                    tc = VALUE/1000
                    tot_ha = COUNT*2500
                    tot_cs = tc*tot_ha
                    cursor.updateRow(row)
     if ap.GetRasterProperties_management(tc_1k, "ALLNODATA"):
          tc_1k.save(temp_ws + "\\" + "0sc" + str(sc) + "_tc" + str(mc_counter+1)) # ==> TESTING DATA!!!
     print tc_1k‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Thanks again!
Tags (1)
DanPatterson_Retired
You could export the raster table to a standalone table or a table in a geodatabase
RenanBarroso
And how can I do that in arcpy? I was also wondering if there is a way to have the raster attribute tables in numpy array. I have tried the RasterToNumpyArray, but without success. The thing I want to do seems quite easy but I'm really struggling with it =/.
Thanks again!
I use RasterToNumPyArray all the time.  What was your problem.
pth = r"C:\Temp\dem.tif"
pth = r"C:\Temp\myarray.tif"
a = RasterToNumPyArray(pth)
a.shape
Out[7]: (50, 50)
a
Out[8]:
array([[68, 33, 78, ..., 53, 39, 89],
       [87, 88, 22, ..., 75,  7, 96],
       [69, 51, 77, ..., 84, 69, 83],
       [73,  0,  1, ..., 29, 25, 88],
       [81, 60, 94, ..., 28, 23, 68],
       [47,  5, 55, ..., 19, 78,  9]])
a - a.mean()
array([[ 17.9472, -17.0528,  27.9472, ...,   2.9472, -11.0528,  38.9472],
       [ 36.9472,  37.9472, -28.0528, ...,  24.9472, -43.0528,  45.9472],
       [ 18.9472,   0.9472,  26.9472, ...,  33.9472,  18.9472,  32.9472],
       [ 22.9472, -50.0528, -49.0528, ..., -21.0528, -25.0528,  37.9472],
       [ 30.9472,   9.9472,  43.9472, ..., -22.0528, -27.0528,  17.9472],
       [ -3.0528, -45.0528,   4.9472, ..., -31.0528,  27.9472, -41.0528]])
RenanBarroso
Thank you! Now it is working and I've changed all my raster processing to NumpyArray. Much better!
I have lots of NumPy examples on my blog post if you are interested in numpy functionality with arcpy and other modules.
XanderBakker
Esri Esteemed Contributor
The cursors in the da module do not provide access to raster attribute tables (RAT). The old cursors do. Although I have never used it to write to a RAT, I have used the old cursors to read from it...
https://community.esri.com/message/355845?commentID=355845#comment-633411
