Local build for iOS.
1480
12-05-2018 01:37 AM
GeoDevPathways_Data
I am trying to make a local build for my app in AppStudio using Qt 5.11, XCode9.3 and Appstudio 3.1. All the tools are installed as required here Install development tools for local Make—AppStudio for ArcGIS | ArcGIS
The error i receive is : Code Signing Error: Provision file "XXXXXXXX" has app ID "com.xxxxxx.xxxxx.ios", which doesn't  match the bundle ID"com.xxxxxx.xxxxx.AppStudioApp". I have put the correct bundle ID and certificate file, I am curious how app studio supplied Bundle id with .AppStudioApp. The agony is i have been able to make a local build using Qt 5.9 xcode 8.3 and appstudio 2.1 back in march. But after the updating now i am stuck here and couldn't move forward.
Would appreciate if someone can help
ShobanaSuresh
The build error you've described above is caused due to Qt bug introduced in Qt5.11.1. [QTBUG-70072] PRODUCT_BUNDLE_IDENTIFIER is ignored in creation of Xcode project - Qt Bug Tracker
In Qt5.11.1, the app's binary name gets added as a suffix to the bundle id. Target binary name for all AppStudio apps is AppStudioApp.
This bug has been resolved in Qt5.11.2. AppStudio 3.2 which is planned to be released soon will be based based on Qt5.11.2
Below workaround can be used for now to get the builds working with Qt5.11.1.
- Open the file ~/Qt5.11.1/5.11.1/ios/mkspecs/features/mac/default_post.prf in a text editor.
- Comment out below line which adds the target binary name as a suffix to bundle id i.e., Add # at the start of the line
# xcode_product_bundle_identifier_setting.value = "$${xcode_product_bundle_identifier_setting.value}.${PRODUCT_NAME:rfc1034identifier}"
- Save the changes and rebuild your app
Hope this helps
Shobana
ShobanaSuresh
Hope this helps
Shobana
