ArcGIS JS 4.9 MapView.when not getting called
1757
11-30-2018 03:21 AM
PraveenTirumandyam
I am creating a MapView but, am not able to see the same. When initially I looked into the browser tools what I found was that canvas element that is created by ArcGIS JS api is not getting created under the view-root. Moreover, there were no queries to load webtiles.
To check is view is getting created, I wrote callbacks for MapView.when. But, I am not getting either callback or, errorback.
What might be happening here? I am fully flummoxed.
RobertScheitlin__GISP
Please provide a sample that demonstrates your issue.
Angelo_BryanPerito
its been a while since you posted this. did you able to solve the issue? i also got the same problem
require(["esri/Map","esri/views/MapView"],(Map,MapView)=>{
   var map  = new Map({ basemap:"topo"});
   var view = new MapView({map:map,"container":"map"});
   view.when(()=>{
     alert('loaded'); //this was not being invoked.
alternately, i include center(lat/lon) and zoom level(17), but still doesnt do anything.. no request happening on networktab of chrome. but it does load the .js files.
