Is it possible to save projects directly to my Dropbox folder?
4179
6
11-29-2018 12:28 PM
BenjaminRifkin
I have my entire file directory set up through Dropbox. When I try to save an ArcPro project it does not give me the option to save to my Dropbox directory. This works with ArcDesktop, so I have avoided moving to Pro until I figure out how to include my projects with the rest of my files. Is there a way to save Pro projects to Dropbox?
Lake_Worth_BeachAdmin
open file explorer and type in the address bar "\\serverName\folder\folder\"
replace serverName with the networkshare and folders with the rest of directory path...
AdrianWelsh
MVP Honored Contributor
Ben,
I would think you would just connect to it like you would connect a new folder. Try these steps:
Connect to a folder—ArcGIS Pro | ArcGIS Desktop
BenjaminRifkin
Hi Adrian,
Unfortunately, when I open up my file directory to save the project, my Dropbox folder does not appear on the panel.
I also cannot seem to find a way to connect to my Dropbox folder when I save the project to my desktop. Maybe it has to do with configuring my drive, but the Pro interface seems to be limiting the folders that I can access.
AdrianWelsh
Ben,
Is your dropbox folder listed like C:\Users\[yourname]\Dropbox?
On the insert tab, click on Add Folder
Then just navigate to that Dropbox folder:
BenjaminRifkin
I think it is actually a networked drive, so it does not show up in my C:\ drive.
AdrianWelsh
Can you find the path of the networked drive? It might be something like 168.128.0.1. \ whatever \ whatever, something like that.
