Can't add an ArcGIS Server Web Service
585
11-27-2018 01:35 AM
BrandonPrice1
I queried out some data from a layer in the ArcGIS Server Rest to add to my web map using the add layer from the web feature. My url is: https://services9.arcgis.com/ZP6Sg2L0zjLDGQa9/ArcGIS/rest/services/CAMS_ADDRESS_LANDMARK/FeatureServ...
I have been able to add the queried layer this way before. Anything I am doing wrong?
ArcGIS REST API
ArcGIS Server with JavaScript API
@ago
JakeSkinner
Esri Esteemed Contributor
Hi Brandon,
Try just adding the REST Service URL:
You can then apply the filter in the Web Map.
