Python Script DDP
639
11-27-2018 05:20 AM
JB
Good morning,
I looking to have two data frame on the same figure. Both data frames have three layers they are all the same (roads, parcels and alternative routes) The strip index has a definition query on the top data frame to run the even strip index and the bottom data frame to run the odds. I just need help finding something that will run these data frames together. If I do it without a script Arc only runs the top data frame but not the bottom. The client just wants to eliminate the number of pages that is the reason they want it split up. Hopefully that makes sense.
Tags (1)
JoeBorgione
Perhaps you could provide more detail on your needs.
