Laptop, Docking Station, Dual Monitor Setup Recommendations
913
11-26-2018 01:39 PM
LaceeCofer
Hi all,
I am looking to purchase a laptop to use with a docking station and dual monitors at home. I want a laptop rather than a desktop to allow for work while I travel. Do you have any product recommendations or specific setups that you like? I have a good idea of what specifications are needed, but I wanted to hear from people who have worked on a setup like this before. Thanks!
More info: I will be using either Arc Desktop 10.6.1 or ArcGIS Pro 2.2, along with work in ArcGIS Online, Portal for ArcGIS, and Esri mobile apps, like Collector. I will also be creating/running very basic python scripts.
JacobBoyle412
Hey Lacee,
I always recommend taking a look at the specs from the Esri Partner Network page for Dell.
I'm not advocating you purchase through Esri, but use the specs as a starting point for discussions with IT: Dell
Let us know if you have further specific questions.
Jacob is a Sr. Solution Architect for Esri Professional Services and loves conservation planning, woodworking, LEGO, and his dogs.
MichaelVolz
Esteemed Contributor
Lacee:
Did you ever make a laptop purchase with docking station?  If so, did you run into any issues running Pro when using the docking station as per other GeoNet posts:
https://community.esri.com/thread/236952-pro-maps-wont-load-when-using-docking-station
