Trying to change coordinate system, points wont show up. Even though it is the correct coordinate system
1676
07-16-2019 02:26 AM
JamilHazim
Hi all,
I started arcgis recently and I came accros a problem I couldn't solve for some time now.
I have a csv file with locations of drillings in the Netherlands. I know the x,y coordinates of the csv file are in RD / Amersfoort coordinates (The dutch national coordinate system). I tried both of them at least.
When I change the basemap coordinate system to one of these, the map changes visually pretty drastically. But when I hover with my mouse over the map to see the x,y coordinates. It is exactly the same as before (mercator).
And I can see 1 point in the middle of the ocean somewhere. So something isn't going right. There should be points all over the Netherland.
My process -> open arcgis pro with a standard basemap -> Set the basemap to RD coordinate system via properties -> add csv file -> display x,y data -> set coordinate system to current map.
Hope you can help me with my problem!
PeteCrosier
What does your CSV file look like?
JamilHazim
HI the problem is solved. It was just the wrong coordinate system apparently.
