Attribute Table Alternatives
947
11-21-2018 02:39 PM
PatrickMaguire
Hi all,
I'm wondering if there are any custom built alternatives to the attribute table widget.
Specifically, I'm looking for a widget that supports advanced filtering of of layers and result sets that are client only (no server url, generated dynamically via a feature collection). Unfortunately, all the filtering options (and the export to CSV option) either don't work or are disabled for these kinds of layers in the standard Attribute Table widget.
The specific workflow I'm looking to support is:
Generate dynamic layer (such as the results layer from the query widget). Load it into a table. Be able to sort and filter table on each column. Export filtered/sorted results to CSV.
Thanks!
Patrick
RobertScheitlin__GISP
Patrick,
  I have not seen any such custom widget out there in the community.
Patrick,
PatrickMaguire
Thanks Robert. Guess I'll go down the customize it myself route.
