How would you do this in Pro?
762
11-15-2018 11:43 AM
ThomasColson
I have a new requirement that, in some 200+ ArcGIS Feature Services on Server 10.6.1 (They are not hosted via a PTL), they all get an "ELEVATION" field and users will somehow magically populate the elevation using a local, Lidar-derived DEM (so it can't be the AGOL elevation service).
Here's what's not going to work:
Use Extract Values to Points (which creates another FC), join back to the original feature service, calculate field using RASTERVALUE: To many steps, users mostly stop understanding the workflow after the word "join". GIS is not these folks job, they GPS some things, add the points to a feature service, need to know the elevation...
The requirement is the Lidar-derived elevation, not the GPS one
Z-enabling everything. Not possible in our environment, nor feasible given the number of SDE feature classes we'd have to modify.
Can't use SQL on the back end like
ELEVATION = (SELECT pdata.getValueByLoc(1,p.SHAPE.Long,p.SHAPE.Lat)  FROM [dbo].[DEM10MP]),
which uses ST_RASTER, an unsafe assembly which we're not allowed to use.
Surely someone (many hundreds in fact) have had this requirement....and solved it? Some python toolbox is out there somewhere......
KoryKramer
Esri Community Moderator
I haven't checked but would Add Surface Information—Help | ArcGIS Desktop work with the services?
ThomasColson
yes and no, the problem is I then have to script, or otherwise automate, the calculation of Z for each new point added.
ThomasColson
Based on arcpy - Extracting value of raster for specific points (with X and Y coord) and write to column in A...  I baked the code sample into a toolbox which seems to be working well based on a morning of comparing tool results to spot checks:
import arcpy
import numpy as np
update_feature_class = arcpy.GetParameterAsText(0)
source_dem= arcpy.GetParameterAsText(1)
elev_attrib= arcpy.GetParameterAsText(2)
rast = arcpy.Raster(source_dem)
desc = arcpy.Describe(rast)
ulx = desc.Extent.XMin
uly = desc.Extent.YMax
lly = desc.Extent.YMin
#Spatialrefernce
sr = desc.spatialReference
rstArray  = arcpy.RasterToNumPyArray(rast)
with arcpy.da.UpdateCursor(update_feature_class,["SHAPE@",elev_attrib]) as uc:
    for row in uc:
        pnt = row[0].projectAs(sr)
        #assuming every point falls to the left and below uperleft corner
        deltaX = pnt.centroid.X - ulx
        deltaY = lly- pnt.centroid.Y
        arow = int(deltaY/rast.meanCellHeight)
        acol = int(deltaX/rast.meanCellWidth)
        row[1] = rstArray[arow,acol]
        uc.updateRow(row)
