4.9 Locate widget icon doesn't appear in IE11, even if I replace it?
654
11-08-2018 02:29 AM
ShakilChoudhury
New Contributor III
The icon for the Locate widget does not appear in IE11 and I've replaced it like so:
.esri-icon-locate:before {
  content: "\e949";
But it still doesn't appear. Tried on IE11 on multiple PCs but still doesn't appear. Anyone know how to fix this?
Tags (1)
MikkLauringson
Still broken in 4.10 for IE.
The span inside Locator div should have class='esri-icon esri-icon-locate', but it has only class='esri-icon'.
I solved it with CSS
.esri-locate .esri-icon:before {
    content: "\e630";
.esri-locate .esri-icon-loading-indicator:before {
    content: "\e65e";
.esri-locate .esri-icon {
    font-family: 'CalciteWebCoreIcons' !important;
    speak: none;
    font-style: normal;
    font-weight: normal;
    font-variant: normal;
    text-transform: none;
    line-height: 1;
    -webkit-font-smoothing: antialiased;
    -moz-osx-font-smoothing: grayscale;
ShakilChoudhury
New Contributor III
Only way I found to get around it is:
setTimeout(function(){
  locateBtn.domNode.innerHTML = "<span aria-hidden='true' class='esri-icon esri-icon-locate'></span><span class='esri-icon-font-fallback-text'>Find my location</span>";
}, 3000);
MikkLauringson
    content: "\e630";
    content: "\e65e";
    speak: none;
    font-style: normal;
    line-height: 1;
StefanUseldinger
Occasional Contributor II
This bug seems to be fixed with 4.12
