Web Adaptor install on linux
1193
11-07-2018 09:28 AM
TonyCallender
I tried to use the ./configurewebadaptor.sh, and it returns unable to connect to Portal URL
./configurewebadaptor.sh -m portal -w https://<web server>.sbcounty.gov/<web adaptor name>/webadaptor -g https://<Portal Server>.sbcounty.gov:7443 -u xxxxx -p xxxxx -a true
Unable to connect to Portal URL : https://<Portal Server>.sbcounty.gov:7443
Has anyone run into this?
We are running ArcGIS Enterprise 10.6.1 on SuSE 12sp3.
Any insight would be appreciated.
JonathanQuinn
Esri Notable Contributor
Can you connect to the URL with curl on the machine?
Is the certificate CN set to the <Portal Server>.sbcounty.gov?
TonyCallender
We cannot connect to the url uing curl. The certificate CN is set to <Portal Server>.sbcounty.gov
