Does anybody know which is the correct way to place an "Under Maintenance" page in Portal for Arcgis ?
Solved! Go to Solution.
You can edit the organization settings to indicate the portal is in maintenance mode:
Configure general settings—Portal for ArcGIS (10.6) | ArcGIS Enterprise
You can also add a classification banner but repurpose it for a notification:
Set advanced portal options—Portal for ArcGIS (10.6) | ArcGIS Enterprise
classificationBanner—Indicates if a security banner shows at the top and bottom of every page in the application. The default is false. To display a security banner, replace the classificationBanner:false line with code that defines your banner. The following is an example:
classificationBanner : { text : "UNCLASSIFIED", color:[255,255,255], font:{ decoration:"none", family:"Portable User Interface", size:16, style:"normal", weight:"bold" }, height : 5, backgroundColor:[0,128,0] },
Set the UNCLASSIFIED text to whatever you want and you can change the color to red, for example.
Thanks for your help, I'll give it a try
Regards
Gustavo
