"Under Maintenance" in Portal for Arcgis
1916
11-07-2018 08:32 AM
GustavoDrets
Does anybody know which is the correct way to place an "Under Maintenance" page  in Portal for Arcgis ?
JonathanQuinn
Esri Notable Contributor
You can edit the organization settings to indicate the portal is in maintenance mode:
Configure general settings—Portal for ArcGIS (10.6) | ArcGIS Enterprise
You can also add a classification banner but repurpose it for a notification:
Set advanced portal options—Portal for ArcGIS (10.6) | ArcGIS Enterprise
classificationBanner—Indicates if a security banner shows at the top and bottom of every page in the application. The default is false. To display a security banner, replace the classificationBanner:false line with code that defines your banner. The following is an example:
classificationBanner : {     text : "UNCLASSIFIED",     color:[255,255,255],     font:{       decoration:"none",       family:"Portable User Interface",       size:16,       style:"normal",       weight:"bold"    },     height : 5,     backgroundColor:[0,128,0]   },
Set the UNCLASSIFIED text to whatever you want and you can change the color to red, for example.
JonathanQuinn
GustavoDrets
Thanks for your help, I'll give it a try
Regards
Gustavo
