How to use view.goTo?
13917
9
11-07-2018 01:37 AM
ShakilChoudhury
I have an x, y, spatialReference and zoom value that I need the map to go to. My map uses a custom basemap (same as the given spatial reference) and the view uses an extent value like so:
var view = new MapView({
container: "viewDiv",
map: map,
extent:new Extent ({"xmin": 554418, "ymin": 166279, "xmax": 584505, "ymax": 144457, "spatialReference":{"wkid": 27700}})
I can't get view.goTo to work no matter what I do.
Tags (3)
RobertScheitlin__GISP
Shakil,
  Can you provide a sample?
ShakilChoudhury
var ex = new Extent({
center:{
x:564460.8649987298,
y:139625.260181187
view.goTo(ex);
ShakilChoudhury
Managed to get it working:
var geo = view.center;
geo.x = x;
geo.y = y;
view.goTo({
geometry:geo,
zoom:zoom
TravisBock2
Worked for me as well.  I have run into this a couple of times now.  I think the documentation or api needs to be fixed. Documentation reads like the original should of worked and then {target: someGeometry} should work. Maybe I'm reading it wrong but I don't see any mention of using the geometry attribute for target.  Am I reading this wrong Esri?
Travis,
   No you are not reading anything wrong. When an Object is passed to the goTo method then the Object should have a property of target that points to a Number[]|Geometry|Geometry[]|Graphic|Graphic[]|Viewpoint. If you are not wanting to Also pass a zoom, scale, or center property with the target then you should just pass the Number[]|Geometry|Geometry[]|Graphic|Graphic[]|Viewpoint directly to the goTo method.
GregoryBologna
Is zoom required if you're requesting the map to be at full extent?
I'm not able to move to full extent. If I add zoom, the map just zooms.
   var featureLayer = map.layers.getItemAt(1);
        view.goTo({
          target: featureLayer.fullExtent,
          zoom: 11
        }, ZoomOptions);
Using it like this does nothing
         view.goTo(featureLayer.fullExtent);
Gregory,
    According to the API docs view.goTo(featureLayer.fullExtent); should work.
hoogw
my working code:
     if you want to zoom to feature layer extend, use below function
function zoomToLayerExtent(layer)
if you want to zoom to lat, long, use below function
function zoomToLatLong(__lat, __long, __zoom){
var _url = "https://maps.lacity.org/arcgis/rest/services/Mapping/NavigateLA/MapServer/1"
var featureLayer = new FeatureLayer({
                                url: _url
map.add(featureLayer);
featureLayer.when(function() {
zoomToLayerExtent(featureLayer);
zoomToRealLocation(featureLayer)
function zoomToLayerExtent(layer) {
         return layer.queryExtent().then(function(response) {
           view.goTo(response.extent);
// bug fix https://community.esri.com/thread/224073-how-to-use-viewgoto
// https://developers.arcgis.com/javascript/latest/api-reference/esri-views-MapView.html#goTo
var esri_point = new Point({
latitude: __lat,
longitude: __long
var esri_goto_option = {
animate: true,
duration: 200,
view.goTo({
       target: esri_point,
          zoom: __zoom
}, esri_goto_option)
.catch(function(error) {
if (error.name != "AbortError") {
console.error('zoom to real location, view goto error', error);
hoogw
works with v4.12 and v4.16
