Hidden/calculation fields returning dates instead of decimal calculations on custom report
1851
10-30-2018 02:12 PM
ChrisShuck1
I am trying to use either the calculate or hidden field types to round a decimal. When I check the answer by inserting the expression/tag into a note field or a decimal field, I can see that it is working as intended within the survey. However, the rounded decimal does not show up on the custom report, it instead returns a date that is slightly before the start of Unix time:
I've tried using esriFieldTypeSingle and using bind::type decimal, although I can't use the two together as this results in an error. If I use a decimal field type, rather than hidden or calculate, the rounded decimal shows up on the custom report. But I do not want this field to be visible on the survey. The xls is attached and the fields in question are highlighted purple (length, width, and thickness). Please help.
JamesTedrick
Esri Esteemed Contributor
Hi Chris,
Apologies for the late reply.  After your post, we released version 3.1, which included improvements in the handling of hidden/calculate questions in the report generator.  In testing your form now, I'm no longer seeing the issue you describe- are you still seeing this problem?
ChrisShuck1
Hi James,
I haven’t had any issues with this function of late. It’s been working well. Thanks for getting back to me.
-Chris
